MiElectrician
- mi
I installed a plug on an ite bus duct and checked voltage and was getting something weird so I eventually pulled the plug off and there is a single hole drilled in each bar right where the plug should connect, inside these holes it looks like someone stuffed a zip tie in there and cut it just enough to leave an inch on each side. Has anyone seen this before? I'm wondering if this was factory done or afterwards, the bus duct looks fairly new, if guess less than 5 years old. I just switched to a different window, but I'm still curious, thanks all
