I have a customer who has a service receptacle under the main panel outside... It is on a single pole 20 amp breaker all by itself and is reading 220 volts ... The neutral is connected to the neutral bar ,, hot to breaker and ground to the separate grounding bar ... When they put a meter on the neutral bar and the ground bar ,, its reading 117 v ..
