Now that article 555 includes residential piers I have a few questions.
1) Can uf wire be used if its 12-3 and use the red as a ground.
I believe you can not tape wires less than 6 awg as green.
2) can Non Metallic liquid tite be used?
I only see where it says anything above the deck needs to be in rigid or pvc.
3)Is it Now saying you have to protect the supply cable going to the outlets from the panel?
So you have to use a gfi breaker to protect the wiring going to the outlet on the pier.
