RXXXC
New member
- Callahan , Fl
Can a Florida electric sign contractor change out lot light fixtures ?
What is outline lighting? It may apply!
Where are you located? There's a sign company in Tallahassee that I've seen changing out site lighting heads to LED. Just curious if you've seen the same outfit.
And that crosses into gray area unless what is being installed is a listed sign. Sign installers generally can only do wiring/maintenance within the sign, and can not run the circuit conductors that supply the sign. Outline lighting is more premises type wiring unless it is actually a listed sign, but they still can't run the supply circuit to it.Outline lighting is an arrangement of incandescent lamps or electric-discharge lighting or other electrically powered light sources to outline or call attention to certain features, such as the shape of a building or the decoration of a window [Art. 100].
They would be legal if they are dual licenced (lighting and sign) or have an unlimited licence.
True, but I only saw their sign cont license number on the truck.
Does Florida issue separate numbers for specialty licenses if you have both sign and lighting maintenance?
