MJRobinson
- Chico, CA, USA
The panel itself is rated for use on 208Y120 3 phase 4 wire, or 240/120 3 phase 4 wire delta, 400A with a 100% Neutral. The panel "doesn't care". Some of the breakers USED inside of that panel might care because if it is 3Ph4W delta, any 1 or 2 pole breakers plugged onto B phase would need to be rated for "straight" 240V, not "slash rated", meaning not 120/240V. 3 pole breakers wouldn't matter, neither would it if you have 208Y120V.
Good point.Hope nothing is on breaker #4 ( 2nd breaker right row) or maybe the handle tie is missing.
Good point.
Took me a while to get it, but I see it now. That's a single pole breaker on B phase...
Single pole QP breakers are only rated 120V.
It's either 3-single poles or a 3 pole missing the handle tie, not real clear but also looks like 30A.
I have seen this mentioned before, when would you EVER use a 1 pole breaker on "B phase?? I was taught high leg is unusable for 1 pole feed.
I was taught never to use it and I don't but you can hook up to the high leg and make stuff like motors or lights work.
It will run a single phase motor just fine, at 208V and with limited current because it has one and a half winding resistance and probably open delta (higher impedance feering the B wire.)I don't even see how it would run a motor, because if you look at it from a vector stand point it is really sharing 2 phases B phase and half of A or C. A light maybe but not a motor.
:thumbsup:You CAN use it, but it's DIFFICULT to use it, because as said, MOST of the 1 pole breakers are not going to be rated for more than 120V L-G. But if you use bolt-on breakers, you can do it if you pick the CORRECT breakers. Since I know Siemens, an example is that the QP plug-in breakers are only rated 120V, as are their bolt-in sisters, the BQ series. But if you use the BQD series bolt-ons, i.e. what you would use in a 480/277V panelboard, the single pole breakers are rated for 277V, so those can be used.
The only plug-in breaker arrangement that I know of where you can do this is an I-Line Square D panel. That will cost someone a LOT more money just to get a 208V 1 pole plug-in breaker. That makes it never worth it.
