goldstar
- New Jersey
- Electrical Contractor
I came across this article on the EC&M magazine website and I thought about the swimming pool work and repairs that I do:
http://www.ecmweb.com/safety/compan...lawsuit-admits-not-having-permit-pool-repairs
What I found to be of importance is that I often change out pool motors at a day camp facility in NJ and I never take out permits for this (there are a total of 4 swimming pools and a lake with an aerator pump). My reasoning is that I am not doing any new work - just replacing like with like. When the pumps and motors were originally installed they were properly installed and passed inspection. If I happen to find anything improper, damaged or out-of-the-ordinary I make the correction. I often have to do more than just the electrical work and I actually, physically replace the motor and often the pump housing as well. Do any of you think that I am in violation of any Codes or laws by doing this ?
It should be noted that when any of these pool motors fail or seize up, no one is permitted in the pool until the repair is made and ALL electrical connections and groundings are properly made and pump is primed and running. I've also installed a 55KW, 3-phase generator just for the pool motors. They often have power outages on real hot days and if the kids continue to swim in the pools the PH factor drops below an acceptable level in a short amount of time.
It should also be noted that another EI comes in at the start of each season to update and certify ALL the pool(s) grounding and bonding connections.
Any thoughts you have would be appreciated.
Thanks.
Thanks.
