Leo1
- Los Alamos, NM
I have a new single family dwelling with Square D single-pole dual function AFCI and GFCI circuit breakers that over the period of a week approx. 12 will trip. I reset them and within appox. a week they trip again. Some the AFCI and GFCI circuit breakers are in rooms not occupied and have no load on them. The home is off the grid, its primary power is by an 8kW photo-voltaic and battery system that handles the home well for about 80% of time. When the dryer or range is used (or protracted period of cloud cover) a supplemental small diesel generator handles the surge in loads.
I would greatly appreciate all troubleshooting tips to help me address the tripping AFCI and GFCI circuit breakers. The home was completed new in early 2017 and went through multiple state electrical inspections passing all with Green tags. The PV system and diesel generator factory reps have been to the home and verified wiring of their respective systems are correct. No obvious defective equipment/loads on the CBs have been found causing the problem.
Thank you.
Thank you.
