Mike106
- Atlanta, Georgia, USA
Does anyone bury EMT in any of their installations? If yes, what kind of fittings do you use?
The only time I bury EMT is when I using it as a stake to hold up some PVC that's about to get concreted.
The only place I would recommend burying EMT is in the mojave desert. To answer your question, you would use compression fittings. :happyyes:
-Hal
it's pretty alkaline there, up to 9.0. it won't hold up well.
and we all know EMT won't hold up most anywhere. why
you'd consider it is a bit of a mystery to me, with PVC being
cheaper, faster, and better.
Sure it is, just takes a lot longer to degrade.PVC isnt biodegradable....
If there was either a like button or a thanks for this useful post button I would hit that......
What about RMC or IMC on certain occasions or even HDPE?I don't get burying anything other than DB cable or PVC.
Can depend on size of the backhoe and you have to factor in size of RMC as well. 1/2 RMC - I can do some damage with my mini-excavator, 4 inch RMC - not so easy. 1/2 RMC and a big excavator - not much of a challenge.RMC can be buried shallower, and a guy is not likely to ram a shovel (or even a backhoe bucket or ditch-witch) thru RMC like UF cable, which gets a little more important as the voltage goes from 120 / 240 to 277 / 480.
