Announcement
Collapse
No announcement yet.
208 3ph to 230-240 Y transformer
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Wondering if it's OK to connect a 208 3ph 230-240Y 112kva transformer to a 3phase subpanel the input current is 100amps
    #2
    Whats the 240Y for? Your source is 208 volts and the secondary is 240Y?
    Comment
      #3
      I'm curious, why that large of a transformer for a 100-amp circuit?
      If you have the proper OCP in place, I don't believe the NEC has a problem in under using a transformer's rating. I have heard that transformers might waste more energy when lightly loaded.
      Comment
        #4
        It will feed a 3ph sub panel that is powering a bunch of 240 3ph equipment one is a 100amp welder.
        https://www.larsonelectronics.com/p-...BoCQuwQAvD_BwE
        This is the transformer they want me to get. Sorry it a 75kva not 112 that was wrong
        Comment
          #5
          That transformer is single phase. You won't be able to power 240 3ph equipment with it.
          Maybe the wrong link?
          Comment
            #6
            So I'm guessing that this will be a 3Ø, 3wire, 240 volt system without a neutral? If you need to supply any 120 volt loads then a 3Ø,4W Delta secondary might be better. A 240 volt Wye system has a phase to neutral voltage of 139 volts.
            Rob
            All responses based on the 2017 NEC unless otherwise noted
            Comment
              #7
              Larson gave me 2 quotes here is the other one
              https://www.larsonelectronics.com/p-147482-.aspx
              Comment
                #8
                So we are trying to keep from running a new service which would entail changing a main panel to a 400amp and doing a hot tap and 200ft of new wire
                Comment
                  #9
                  112.5kva is the correct one.
                  Yes it can be done- make sure your sub panel has straight rated breakers only and no 120 volt loads.
                  Comment
                    #10
                    OK cool. So if they wanted 120 also could I get a transformer that would do that also?
                    Comment
                      #11
                      You would use the 208 volt system for that.
                      Comment
                        #12
                        Look at post #6.
                        Rob
                        Comment
                          #13
                          Very confusing thread; let's try to clarify:
                          So you HAVE a 208V 3 phase system, right?
                          They WANT you to supply their equipment with 240V 3 phase, is that right?
                          If so, on that 240V system, do they need you to have 120V single phase as well?
                          __________________________________________________ ____________________________
                          Many people are shocked when they discover I am not a good electrician...
                          I'm in California, ergo I am still stuck on the 2014 NEC... We'll get around to the 2017 code in around 2021.
                          Comment
                            #14
                            Have you done a load calculation for the new equipment? Is there room in the existing service load calculation to accept the new loads?
                            And that 112 kVA transformer is overkill for a 100-amp sub panel.
                            Comment
                              #15
                              Yes there was. Well they ended up not using the transformer they ended up doing a new 400amp panel, disconnects 200ft of wire and $24,000
                              Comment
                              Working...
                              X
