Greg1707
- Alexandria, VA
- Business owner Electrical contractor
I plant to run PVC under ground from disconnect to spa. There is a one inch hole in the side of the spa provided for the wiring. There is no way to access the other side of the inlet without removing parts of the wood siding. What is the suggested wiring method once reaching the spa? Stub in a short piece of PVC and then just run the #8 THHWN conductors unprotected to the control box?
