For 3" sch. 80, you need something that's made for heating pipe that size.
In our shop we would use a 6" greenlee hotbox, a propane hotbend torch, or a large greenlee blanket.
We will use our Milwaukee heat guns on 3/4 pvc every once in a while but that's about it.
As a second option, if you can't buy an elbow online and get it expedited to you,
I would take this opportunity and instead invest in something that can heat larger pipe.
It sounds like you need it.
i've got one sitting in my backyard right now. absolutely kicks ass.
i have bent 4" sch. 80 with it, but you best put pipe plugs in to
hold in the heat and pressure, so it doesn't collapse.
i've just finished my pool, and as wonderful as this widgit is, it's going to
a new proud owner. i'm done doing large underground, and so it, and a
set of pipe plugs, is up for sale.
they are $850, and the pipe plugs were about $250 ish.
$500 takes all of it.
2" schedule 40? like in pool piping? 30 seconds to a minute.
doesn't burn like a weed burner. you can toast a pipe if you are
a dummy about it, but you have to work at it.
send a pm if interested. shippable tomorrow morning.
