Is the pad just big enough for the spa footprint, or does the pad also serve as the decking?
When it's not required as noted I still put a spiral of #8 copper under the pad, push a 10ft gnd rod down at the edge of pad, clamp the spiral to the rod with bronze clamp, and then extend that copper to spa bonding lug or electrical panel gnd bar or case (if possible). I typically make the spiral with about 12" spacing, from center to about the edge of the pad.
