Announcement
Collapse
No announcement yet.
How do I site, or walk , as straight line to mark a conduit Run w/o a Survey Transit
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    We're dropping 400' feet of 1 inch conduit into the ground. I have to mark a straight line line with a Marking Wand for the Utility Locate and the Backhoe.
    Best thing is to have someone set a survey transit up and watch me -if I wander out of the walking Path-I get a yell to correct my direction.
    Does anyone have any suggestions/ Follow a pickup with a steering wheel held dead center?
    Not the birightest question someone has ever posted on this forum, but I might get some helpful feedback.
    #2
    Stand at point A, pick a landmark inline with point B and start walking. You can also use a compass.
    Roger
    Comment
      #3
      How flat is the ground? Maybe just lay out a rope.
      Comment
        #4
        Or get a plumb bob with lots of string.
        Comment
          #5
          I’ve used a bucket of pull string. Drive a stake at each end of where you want to go, tie string to one end, tighten and tie off at other end, then run your marker along the string.
          Cheap easy way to make a nice straight line. Finding someone who can run a trencher straight along that line........well maybe another story.
          Comment
            #6
            I have yet to meet a digger that can dig a straight line.....~RJ~
            Comment
              #7
              Take a laser level or pointer and set it at point A pointed at point B. Starting at point B, walk toward point A while verifying the laser dot is hitting you. Mark the ground with spray paint as you go. This procedure is best done when it's dark out.
              A string will bow. A laser will not.
              Comment
                #8
                Roger
                Do not do this after drinking alcoholic beverages!!
                Comment
                  #9
                  It helps if you mow the grasses along the path of the string-- fewer snags to make the line crooked!
                  Comment
                    #10
                    well at least its 1" SCH 40 conduit so I don't have too worry too much. Now if it was 12 inch SCH 80
                    Comment
                      #11
                      Do you really think you will be able to achieve a perfectly straight conduit in a 400 foot underground run? Get close and put metallic burial tape in the trench, it can be located when ever needed.
                      Roger
                      Comment
                        #12
                        just tec screw it to the diggers head.....~RJ~
                        Comment
                          #13
                          Exactly. Why does it need to be perfectly straight?? I've never even given that a thought with the miles of cable and pipe I buried. Get a pavement marker paint can and walking handle and start walking. Chances are you are going to have to go around something that's buried anyway.
                          -Hal
                          Comment
                            #14
                            He didn't say it needed to be perfectly straight. But, you do want to lay out a somewhat straight line for the backhoe operator. It's a lot easier to walk that line with the paint, than it is for him to just dig without it, especially since he may very well be driving backward while doing so. The idea in post #2 is usually more than sufficient.
                            Comment
                              #15
                              [COLOR="#800000"]I keep a close watch on UG’s of mine
                              I keep my eyes wide open all the time
                              I know most diggers can’t dig straight lines
                              Because it's mine, I walk the line
                              I find it very easy to transit, tape or string
                              I find myself admitting it’s just not their thing
                              Yes, I'll submit that I've a tool for you
                              As sure as night is dark and day is light
                              There's just no way to make two wrongs a right
                              And litigation proves only deep pockets right
                              They've given me these codes to keep by my side
                              But none of them will matter if they want my hide
                              And it's a given that i'll never turn that tide
                              Because it's mine, I walk the line[/COLOR]
                              ~R(w/apologies to the man in black)J~
                              Comment
                              Working...
                              X
