Announcement
Collapse
No announcement yet.
Ceiling Paddle Fan
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Ceiling Paddle Fan
    Time to upgrade my ceiling paddle fans in my home. Any recommendations on make, model?
    Go to Paddle Fans R Us to purchase?
    Moderator-Washington State
    Ancora Imparo
    #2
    Big Asterisk Fans (that's not their real name-- real name has a different middle part) has a lot of high-power, large-size fans! But probably oversized for your living room.
    ps-- last time I upgraded a fan, I just went to Big Box Hardware and picked a 'nice-looking' one.
    Comment
      #3
      If you want high quality no swinging, go with Casablanca ($$$). Monti Carlo isn't bad.($$).
      I find the box store brands are okay for the money as long as you don't hang them on a pendant and don't mind a little noise and swing.
      Comment
        #4
        I like the looks of minkaaire fans. A bit pricey but nice look.
        Or you get nuts with fanimation fans.. The have standard fans and some pretty pricey and strange fans
        They say I shot a man named Gray and took his wife to Italy
        She inherited a million bucks and when she died it came to me
        I can't help it if I'm lucky
        Comment
          #5
          If you are the meticulous type and have a lot of patience there are balance kits that fit any fan. Static balance is easy, dynamic balance is harder, but less likely to be a problem in the first place. Noise, on the other hand, you take what you get.
          Comment
            #6
            I just installed a 72", 9 blade, brushed nickel fan by Fanimation for a customer and he loved it ( he had it when I got there). It had a DC motor and 6 speeds with remote and LED light (naturally). The price seemed reasonable when I looked it up, sells at Lowe's for $300 ( I don't think that's where the customer bought it).. Kind of a high ceiling so needed a 3 foot down rod.
            It did seem quite enough and very stable.
            It's looked very good and kind of classy in that particular house.
            The best way to choose a fan is to see what may look right and what size would work well and then choose the quality you want.
            The 95% of people that you can't trust give the other 5% a bad name.
            Comment
              #7
              Many of the big box stores sell the hunter original fans. High priced and heavy but extremely quite and last almost forever. I love the instructions where it says that after 10 years you may want to check the oil.
              Comment
                #8
                Good advice. Also, before putting in any fan with a high ceiling, make sure there are no lights above the fan shining down through it!!! Worst case the customer will just have to leave those lights off whenever using the fan. The strobe effect is incredibly annoying, especially with point source lights. Linear fluorescents or LEDs might be OK, as would indirect lighting.
                Comment
                  #9
                  We got lucky on this install and no ceiling lights. The customer wasn't so lucky with another installed a bit earlier. They put up another fan with a remote and left it powered by the dimmer. Messed up the remote. I actually think the customer did it himself and didn't want to admit it.
                  Comment
                    #10
                    I believe I am meticulous and patient, for the most part. For me, if the fan is out of balance I return it. I won't bother with the counter weights. I just picture the weights flinging of the paddle blade and catching some one in the eye or breaking something.
                    Comment
                      #11
                      First thing I do after installing a fan is to make sure the blade bracket screws are tight into the motor, and lift the blade as I tighten them.
                      Second is to make sure the blades are in the same plane by slowly rotating the fan while sighting along a line to a fixed point behind the fan.
                      I think I've only had to balance two fans with the weight kit, and I've installed a lot of fans over the decades.
                      Master Electrician
                      Electrical Contractor
                      Richmond, VA
                      Comment
                        #12
                        Needed to replace an outdoor fan on my porch last year and wanted to go cheap due to salt air environment, it also hung on a 4' stem. Well, I found a $100.00 model that had the look I was after but my wife on another isle found a $51.00 model so I said what the heck and went home with it. I cut a piece of 3/4 EMT to make a stem and hung it, figured it would swing crazy, turned it on and when I was moving the ladder I crammed it into the blades, oooops. Finally got out of the way and this fan is the most stable fan I have ever hung, almost no movement at all.
                        So if you have a swinging fan just stick a ladder into the blades, it probably doesn't work on a high dollar fan though.
                        Roger
                        Comment
                          #13
                          Roger, I bought a real cheap fan 20 years ago and installed it on the second floor but hardly ever go up there. Came home from vacation, fan was off mind you, and there was a blade on the floor. I grab one of the 3 remaining blades and it broke off with the slightest touch. Same with the next two. The metal had fatigued. I guess that is why it was cheap.
                          Had another almost fall on a customer after it was hanging for 10 years. The bracket that the ball rests in fatigued and the fan starting to fall... it was hanging by the wires when I got there. She bought the fan so I don't know if it was cheap or not
                          Comment
                            #14
                            Had this happen in my mother in law’s house while the fan was running. She was in the room at the time. The blade bracket broke and the blade went flying across the room. She’s lucky she didn’t get hit by it.
                            Comment
                              #15
                              Mother-in law you say?
                              You hung the fan?
                              [COLOR=navy]If you aim at nothing, you will hit it every time![/COLOR]
                              Comment
                              Working...
                              X
