- Bremerton, Washington
Time to upgrade my ceiling paddle fans in my home. Any recommendations on make, model?
Go to Paddle Fans R Us to purchase?
If you want high quality no swinging, go with Casablanca ($$$). Monti Carlo isn't bad.($$).
I find the box store brands are okay for the money as long as you don't hang them on a pendant and don't mind a little noise and swing.
Or you get nuts with fanimation fans.. The have standard fans and some pretty pricey and strange fans
I just installed a 72", 9 blade, brushed nickel fan by Fanimation for a customer and he loved it ( he had it when I got there). It had a DC motor and 6 speeds with remote and LED light (naturally). The price seemed reasonable when I looked it up, sells at Lowe's for $300 ( I don't think that's where the customer bought it).. Kind of a high ceiling so needed a 3 foot down rod.
It did seem quite enough and very stable.
It's looked very good and kind of classy in that particular house.
The best way to choose a fan is to see what may look right and what size would work well and then choose the quality you want.
Good advice. Also, before putting in any fan with a high ceiling, make sure there are no lights above the fan shining down through it!!! Worst case the customer will just have to leave those lights off whenever using the fan. The strobe effect is incredibly annoying, especially with point source lights. Linear fluorescents or LEDs might be OK, as would indirect lighting.
If you are the meticulous type and have a lot of patience there are balance kits that fit any fan. Static balance is easy, dynamic balance is harder, but less likely to be a problem in the first place. Noise, on the other hand, you take what you get.
Roger, I bought a real cheap fan 20 years ago and installed it on the second floor but hardly ever go up there. Came home from vacation, fan was off mind you, and there was a blade on the floor. I grab one of the 3 remaining blades and it broke off with the slightest touch. Same with the next two. The metal had fatigued. I guess that is why it was cheap.
Had another almost fall on a customer after it was hanging for 10 years. The bracket that the ball rests in fatigued and the fan starting to fall... it was hanging by the wires when I got there. She bought the fan so I don't know if it was cheap or not
Had this happen in my mother in law’s house while the fan was running. She was in the room at the time. The blade bracket broke and the blade went flying across the room. She’s lucky she didn’t get hit by it.
Mother-in law you say?
You hung the fan?
On a related note...
My daughter had her house built in 2013. I installed a Hunter fan she bought from Lowes in her basement family room. 5 years later, her kids lost the remote. I went back to Lowe’s for a replacement remote. No longer available. She has no receipt or proof that the fan even came from Lowe’s.
But they step up and look up that fan from their history in 2013. Since the remote is not available, the give her store credit for the list price of the fan at the time - $169. I get a replacement that sells for $129 that looks identical to the original and she has $40 left to spend. Lowe’s for the win!!
