Announcement
Collapse
No announcement yet.
Light opinion
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Light opinion
    Does anyone think it would be ridiculous to put a light on both sides of that back door with that one side being so narrow. Would one light look weird need some opinions
    Sent from my SM-G965U using Tapatalk
    #2
    One light, perhaps with multiple sockets/globes, centered above the door.
    Or, if there will be a deck as wide as the house, a flood, higher and centered on the house.
    Master Electrician
    Electrical Contractor
    Richmond, VA
    Comment
      #3
      All I have is "light opinions" I'm all out of "heavy ones"!
      What is that siding block for between the top windows and the doors below?
      Looks like for a light to me.
      Anyway, I was thinking the same as Larry, one, centered above the door.
      [COLOR=navy]If you aim at nothing, you will hit it every time![/COLOR]
      Comment
        #4
        You're right; the center one even has a hole.
        Master Electrician
        Richmond, VA
        Comment
          #5
          I was planning on putting a nice led flood for when iwant to light up the yard, the sconces or sconce ,I was thinking more for everyday
          Comment
            #6
            In that case, a white coach lantern style.
            Master Electrician
            Richmond, VA
            Comment
              #7
              so, a door light, a yard light, and two soffit lights? ~S~
              Comment
                #8
                What's that all the way up under the eves in the soffit? Looks like two recessed lights??
                -Hal
                Comment
                  #9
                  How is anyone, including you, supposed to get any work done with all the construction debris laying around?
                  Comment
                    #10
                    Yes soffit lights
                    Comment
                      #11
                      Originally posted by nickelec View Post
                      Does anyone think it would be ridiculous to put a light on both sides of that back door with that one side being so narrow. Would one light look weird need some opinions.
                      Well folks I'm not seeing enough room to put a carriage light on either side of those doors.
                      There must have been a single door there and when they installed a double door that brought it right up to the window ( they seem to share trim). I really think that double door was a mistake if they couldn't move that little window over to balance things out.
                      Now that it done it's done. I would probably put a roof of some sort over the back porch to kind of hide the fact that everything is so crowded. then put a ceiling light.
                      The 95% of people that you can't trust give the other 5% a bad name.
                      Comment
                        #12
                        I would place the light to the left of the window at the same height you would if you placed it at the door.
                        You should still have plenty of light on the steps and less bugs in the house when you open the door.
                        Comment
                          #13
                          i have my framers/siders put blocks for the lights to go, big enough for a 3 5/8s box. no block, no light. esp on clapboard siding like that. the siders are 'tarded imo. and i agree with the post about the trash all around. how are you expected to work. i would kick that general in the butt as in me no workie till you clean this mess up.
                          The End of the World as i Knew it: 2012. I'm having my Doom's Day now.
                          Comment
                            #14
                            so 4 or 5 lights....seems to be everywhere we go.
                            kitchens that used to have one light, maybe a second sink light, are now designed with UC, in Cab, .....Bathrooms have vanity, shower, toliet, OH, F/L/NL.....i'm doing a bar w/led rope's (light up the top shelf), razors, minitracks....
                            b-b-but...they're efficient!
                            ~RJ~
                            Comment
                              #15
                              I was just wondering who will ever change those soffit lights?
                              Fredericksburg, VA
                              21 Hours from Winged Horses with traffic;)
                              Comment
                              Working...
                              X
