mbrooke
Batteries Included
- United States
- Technician
At what amperage do 600 volt (and under) breakers start to have electronics inside?
As an option or as standard?At what amperage do 600 volt (and under) breakers start to have electronics inside?
Are we to exclude GFCIs and AFCIs? Because those (obviously) include electronics.
The only "electronics" in standard breakers I'm aware of are in adjustable-trip and, loosely, shunt-trip coils.
That's what I meant by 'adjustable-trip' breakers.What about high amp frame breakers with adjustable dials?
Ok, including those cartridges on Spectra breakers?
Yes. In a nutshell once you get to 1000A and above, the requirement for GF trip has pushed everyone to use ETUs (Electronic Trip Units). Years ago you would add an external GF trip unit to an old T-M breaker, but that meant the mfrs had to support inventory for two different versions of the same frame and once ETUs became cheap, it made no more sense. With some mfrs that philosophy has now drifted down into lower frame sizes so even if you order a non-adjustable trip, you are still getting an ETU without an adjustment means. It varies from one mfr to another though.
How do I know I am getting electronics? What breaker brands/models are available today without electronics?
In the coming years we will see this more and more in new equipment as the old NEMA molded case breakers become obsolete and the mfrs become more and more global in focus. Rules that apply outside of North America called RoHS (meaning Reduction of Hazardous Substances, referred to as “rohass”) mean that the fiberglass reinforced plastic used in our old style breakers can no longer be used because it cannot be recycled. Newer breaker designs use different materials but required new frame engineering, leading to incompatibility with some older designs. So although we will still see the older designs made for decades into the future here in North America because of the installed base, it will be relegated to retrofit use and become very expensive. What we already have started seeing is new gear being designed and built to only use the new versions of breakers with no options for the older ones. How that relates to the original question is that many of these newer designs will have ETUs starting at 250A frames as standard.
I don't like everything about globalization Stupid IEC committees.... :rant::rant::rant::rant:
Just curious why you are so eager to avoid electronics in breakers? EMP effects?
EMP, failures from transients, condensation, none standard voltages, ect.
Thank you....
I would say no; the adjustment is most likely electro-mechanical.
