Correct me if I'm wrong and please confirm if correct. When installing heat detectors interconnected with 120v smoke alarms, the neutral gets switched through the heat detector (I believe ??).
If so How is that wired? The neutral connections between the heat detector and the smoke alarm. The smokes get wired to the interconnected hot and interconnected neutral. If I take from that neutral from the smoke and run to the heat (2 wire for switch) then back to the neutral what's it switching?? both sides of the heat detector switch are common and connected to the smoke neutral.(I'm missing some thing???)
Or does the neutral feed get switched through the heat detector and then feed the smoke alarms, ?? But then the smokes wouldn't have neutral and be powered.. please enlighten me.
Two other questions, for garage and attics.... what type of heat detector? Is there a special rate of rise or something???
AND if swapping out existing smokes .... do the heat detectors go bad and should get swapped too?? (I would think not but confirming).
Thank you
Thank you
