I am trying to size the conductors for a submersible well pump.
The pump is installed 600 feet deep with 8AWG run to it from ground level. Power from the transformer is 480 feet away and this where I am wondering how to size the wire. It will be direct burial URD.
The pump runs at 10-12 amps, likely with a startup of maybe 40 amps.
How should i approach the voltage drop calc with these kind of distances? I can get to the well house with 2-2-4 but then there is the 600' of #8 wire to consider.
Do you factor in the pumps startup amps or its running amps when doing the calc?
thanks for the help
thanks for the help
