We want to install 6-4'' conduits into a 30'' x 90'' long 2500a Bussed CT 10'' deep. I am worried about the penetrations into and out of CT can. I will have 6 going in and 6 coming out. Is that 30'' wide enclosure to small? I will feed CT from bottom then send out thru left side at top of CT. Does the angle pull calcs apply to the CT can? If so the CT can is to small correct?Or They dont apply at all and I can install the 6-4'' conduits?
