Electroplaxes
- Nunica, MI
Industrial application, using parallel 3/O THHN for a 400A feed via cable tray. The question is in how to properly enter the panel...
I know Icotek and Roxtec have panel passthroughs capable of handling multiple conductors/cables in one housing but long lead times, pricey, and not as robust as I was hoping (rubber inserts sagging and twisting over time)
I was wondering if there is another way?
I want a robust application that seals the entry from dust and debris. I'm playing with the idea of running them through individual nylon cord grips. My concern is the metal between them, it creates the possible of picking up induced voltage like the core of a transformer. To remedy this I want to take a Carlon (UL listed) 2 gang cover and put cord grips in that. Knock out a 4" square hole and attached the plate to the panel. With all the parts being listed, is there any code restrictions to doing this?
