Xfmr upgrade question
martsco11
Anaheim, CA US
Gentlemen, I have an existing 45kva xfmr (480 3ph to 120/208v 3ph) that I need to upgrade to a 75kva. The existing conduit run is 400' of 1" emt. I need to upgrade the wire to at least #2 thhn to handle the 90-100amp primary. According to the wire fill table I can fit 3 - #2 wires into the existing conduit. Here's the question...
Do I need to derate the wires (use larger wires), or can I re-tap the xfmr to accommodate the voltage loss (3%)? I'm trying not to replace the conduit... Most xfmrs have taps to allow for lesser or greater voltages.
xformer
Dallas, Tx
Master Electrician
Why would deration be necessary? You Have no more than 3 CCC's in the conduit. What about the EGC? Still have room for that along with the 3 - #2's?? :)
petersonra
Northern illinois
engineer
I'm going to use the emt as the grounding conductor.
good choice.
#2 is good for 115A at 75 deg C for thhn. I'd be inclined to see if I could get a 115A CB. I doubt such a beast exists so maybe 110A. I don't see why it needs any derating unless there is a temperature issue and that can likely be resolved by using 90 deg C wire.
martsco11
Anaheim, CA US
Well, other than driving a ground rod or finding building Steel, or locating a cold water ground nearby it's the least of my options. I cannot fit a number 8 ground with the three number twos in a 1 inch conduit according to the NEC. Believe me, I'd feel better pulling in the ground. But I will test it to make sure it's up to par.
xformer
Dallas, Tx
Master Electrician
good choice.
I concur unless AHJ trumps it. :)
You still need a GEC in addition to the EGC run with the primary conductors.
