Gushud
- Massachusetts
If I’m wiring 2 condenser outside for two different units with two different meters each unit haveing there own meter do I need one service receptacle which is one ok per 210.63? also can I run one 3/4 inch pipe and put all the circuit in there and t off to each disconnect so I only penetrate the building once or should I make two separate penetration with two different pipes
