transformers on the roof
Plant has several utility transformers installed on the roof. It has happened before that lightning striked and destroyed them. What would be the best way to protect them from the lightning?
bphgravity
Florida
Re: transformers on the roof
I would install some air termials at higher points along the roof line and maybe build an open enclosure around the transformer to help prevent a direct strike.
Check out sections 250.60 and 250.106 of the NEC. I would also grab a copy of the NFPA 780. :)
