Announcement
Collapse
No announcement yet.
E 26 and E 39 light bulb base question
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    If I have an LED light that is the larger E39 size base, is it ok to buy an adapter to install it into the smaller E26 base ? The light draws 115 watts. Thank you.
    #2
    You mean a mogul base down to a medium socket? Maybe a problem with heat dissipation.
    -Hal
    Comment
      #3
      I think it would work.
      Heat wise you are adding dissipation, plus isn't everything ? 660w rated?
      Comment
        #4
        -Hal
        At a 115 Watts? I don't think so.
        Another Al in Minnesota
        Comment
        Working...
        X
