I inspect a lot of Service changes and upgrades and I always come across projects where the contractor has installed a 200 amp panel in a 1,000 sf house that has all gas appliances. Is this now the standard to just install a 200 amp panel for residential applications? Or do the contractors not know how to size the service properly? Is this strictly for safety? Why are we putting such large panels in such small situations?
Announcement
Collapse
No announcement yet.
200 amp panel Residential all gas appliances
Collapse
X
Supply and demand. 200 amp could be cheaper than a 150 or even a 100. Depends on the supply house. I bought 15 200 amp panels at the end of an inventory year cycle from the supply house because they were ridiculously cheap. They even had copper bus. I couldn’t have bought a 60 amp panel for what I paid for these 200s
Our go to size is 200 amps unless we need more than it is 400 amps. We never look at 150 or 300 amps.... Yeah we can probably save a few bucks but as stated above a 150 amp main breaker panel is a special order around here and would cost more than a 200 amp panel. People are always adding things so we just go for the 200 amp panel especially with car charger etc.They say I shot a man named Gray and took his wife to Italy
She inherited a million bucks and when she died it came to me
I can't help it if I'm lucky
Comment
On a service upgrade there is a higher profit margin on a 200 service. The labor is about the same and you end up with slightly more expensive material cost but the up charge from a 100 or 150 amps to 200 amps can be significant.Rob
All responses based on the 2017 NEC unless otherwise noted
Comment
- Jun 2007
- 290
- Fredericksburg, VA 21 Hours from Winged Horses with traffic
- Electrical Engineer
- Send PM
While the Dominion Energy Blue Book still shows a 100 amp 120/240 service (they also show a 100 amp 120 volt service), I have not seen a new rersidential 100 amp service installed around here on a single family home in over 30 years. And the economies of scale make the 150 amp panel a no show also. The cheaper 200 amp panel ofsets the cost of the larger SEU for a 200 amp panel.Fredericksburg, VA
21 Hours from Winged Horses with traffic;)
Comment
Originally posted by gadfly56 View PostThe only reason the upgrade in my last house was a 150 amp panel was my electrician told me that the overhead from the POCO would have to be up-sized for a 200 amp panel. It was more hassle than I was looking for.
There are 200 amp services all over the country fed from #2 aluminum, #4 aluminum, even open wire #8 CWC...
I can’t understand why you were told that.
Your service size isn’t determined by the POCO service drop.
Comment
Originally posted by mbrooke View Post...- home buyer thinks they are getting more. ...
__________________________________________________ ____________________________
Many people are shocked when they discover I am not a good electrician...
I'm in California, ergo I am still stuck on the 2014 NEC... We'll get around to the 2017 code in around 2021.
Comment
Originally posted by gadfly56 View PostThe only reason the upgrade in my last house was a 150 amp panel was my electrician told me that the overhead from the POCO would have to be up-sized for a 200 amp panel. It was more hassle than I was looking for.Master Electrician
Electrical Contractor
Richmond, VA
Comment
-Hal
Comment
Originally posted by LarryFine View Post
They go by service demand (load letter) not by service rating. I've done many upgrades where they did not upsize the drop or lateral, even on a 200-to-400 amp.Ethan Brush - East West Electric. NY, WA. MA
"You can't generalize"
Comment
Originally posted by electrofelon View Post
Not always. Seems like every 5th service I do, the planner pulls something weird like no LB's, or they have to upgrade the drop if I go to 200.... It's happened.
-Hal
Comment
Comment
