Moosifer
- Panama City Beach, FL
OK, I am kinda lost on this one. New house with no specs and hardly any plans. I think I need something bigger than 400a but my supply houses aren't helping me with anything in that direction.
We don't do a lot of big houses and this one isn't but the electrical is.
So if there is a 450 or 600 amp house panel someone would recommend that won't break the bank that would be great.
I plan on doing 2 or 3 subpanels so I don't need a bunch of breaker spaces outside.
ALSO
I'm trying to figure out the meter panel size for certain to make sure I need more than 400a. I've done some load calculations but I don't have a lot of faith in my capabilities.
It is a 3000sq ft house.
This is where the issues come into play.
2 instant hot water heaters 150a max amperage.
3 kitchens
Split AC units - 9 of them with one 38 min circuit amps for unit outside - they don't seem to draw much at all at the inside units, the specs say min circuit amps is less than 1amp each.
One other split unit for the top floor 36 min circuit amps for other outside unit
Residential elevator
Fire pump
60a hot tub
2 laundry rooms
Owner wants the top floor for his use only when in town. He plans to rent the rest of the house as a beach rental since it is on the beach. Maybe he plans to rent both other two floor separate from each other.
Any help would be appreciated. I plan on going over this with the inspector and probably his boss but I don't want to seem like a total idiot. I'd also like to convince this guy he needs smaller hot water heaters if this is gonna be close or cost me a ton for a bigger panel.
Thank you for your help!
ALSO
3 kitchens
Fire pump
60a hot tub
2 laundry rooms
