Habitable Room.
A room in a building for living, sleeping, eating, or cooking, but excluding bathrooms, toilet rooms, closets, hallways, storage or utility spaces, and similar areas. (CMP-2)
The 2020 NEC has finally defined habitable
The room is ten feet by eighteen feet. It has a dedicated 20 amp plug for the washer.
No other outlets are required per code? Seems odd but from what I'm reading legal?
What would you call this room???? It has a washer dryer...
A big waste of space.
-Hal
Prudent design in this case would dictate additional receptacle outlets, IMO, even if not required.
Chances are, someone will want to plug in an iron in that room eventually.
I agree. I may add a couple receptacles but I wasn't sure the spacing by code....
I should be fine to feed the other receptacles in that laundry room off of the dedicated 20 amp circuit
