AlexJ2406
- Texas, USA
Hey guys! So, I'm trying perform a load analysis on an existing service that we're going to be adding load to and I'm not too familiar with how to pull the information off meters. After doing some research, it seems that the first three characters should read "03A" and this code means that the reading shown is the peak kva. I attached a picture of what the reading was. it's showing 1.84kva.
this is a 208v, 3 phase, 1600amp serivce, so there is a ct involved. The calculated connected load from the previous load analysis shows the connected load at 1440amps, i know the actual operating and peak load will be lower than that, but 1.84 kva at 208v, comes out to about 5 amps.
After doing more research, it looks like when a ct is involved there's a multiplier involved. Am i correct in assuming the multiplier is the "X80" that's written on a sticker near the top? So the actual peak kva should be 1.84kva X 80 = 147.2kva? At 3phase, 208V that comes out to about 409 amps.
Am I going about this the right way or am I missing something here? 409 amps for a connected load of 1440 amps sounds a little off, but I'm not sure that something like this is too uncommon.
Any input is much appreciated!
Thanks guys!
Alex
Thanks guys!
Alex
