NEC 2017 - Section Text 310.104 Missing
ron
I have the regular 2017 NEC softcover book on my desk and was reviewing Table 310.104(A) and just realized that I do not have the text for the Section just before it 310.104. I see it in the Handbook I have as a PDF, but not in the regular code book. Was there a misprint? I can't find an Errata page on the NFPA website that would address this. I just see Errata No:70-17-1 which is for a missing 0 for TW insulation thickness.
Table 310.104(A) is there with no problem.
Part III. Construction Specifications
310.104 Conductor Constructions and Applications. Insulated conductors shall comply with the applicable provisions of Table 310.104(A) through Table 310.104(E).
Informational Note: Thermoplastic insulation may stiffen at temperatures lower than −10°C (+14°F). Thermoplastic insulation may also be deformed at normal temperatures where subjected
to pressure, such as at points of support.
charlie b
Lockport, IL
Retired Electrical Engineer
They are trying to save trees by not wasting available space on pages. ;) The entire text of 310.104 takes up less than one column inch. So they fit it into a small empty space between other unrelated stuff.
