Client just told me today they want the hydronic type baseboards in their house. I am going to talk them out of it. All of the reasons commonly given for why they are better make my BS sensor go haywire and they are 3X the price. Does everyone agree? This is from the Marley website:
I will debunk these one by one.
1. On the contrary it seems like they will result in larger temperature swings since they take longer to heat up once heat is called for, and longer to cool down once the heat setting is satisfied.
2. LOL, whatever bro.
3. They seem to be the same wattage per foot so I dont see how this could be.
4. I understand the difference between convective and radiative heat, but I dont see how a hydronic heater results in less of the former and more of the latter. That moisture argument doesn't make any sense whatsoever.
Does anyone disagree or have any other points?
1. Hydronic baseboard heaters maintain balanced room comfort
Because of the retention qualities of the hydronic element, gentle heat continues to radiate even after the thermostat turns off. This makes for more balanced heating and keeps the room at a comfortable temperature for extended periods of time. Other types of baseboard heaters can’t provide the same kind of balance. That’s why hydronic baseboard heaters are the ideal choice for rooms in your home where you want ultimate comfort, like the living room, bedrooms and maybe the basement. They can also help keep the chill out of kitchens and bathrooms.
2. Hydronic baseboard heaters increase energy efficiency
With this type of baseboard heater, the thermostat cycles on and off less frequently. This lowers energy usage – and your energy bill. These energy savings make this type of heater great for homes and offices alike.
3. Hydronic baseboard heaters are safer for children and/or pets
From playrooms and daycare facilities to veterinary clinics, hydronic heaters are the best choice for rooms where children or pets often play. These heaters have a low surface temperature, making them cooler to the touch on little hands and paws.
4. Hydronic baseboard heaters are better for allergy sufferers
Heating fluid instead of air means more moisture in the air and less chance of dust circulating. People with allergies may notice that fewer symptoms occur in a room with hydronic baseboard heaters, making these types of heaters ideal for their homes.
Comment
