Announcement
Collapse
No announcement yet.
Condulet C sizing 4" conduit
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Is there a condulet c available that I can run 4 500 kcmil + 1 350 kcmil in? the standard ones I see are for 3 350 kcmil max.
    looks like I would need a condulet C that's 32" long! Is that right? does that exist?
    Thanks all.
    #2
    You could make one using a piece of 6" gutter.
    If Billy Idol is on your playlist go reevaluate your life.
    Comment
      #3
      Yes, it needs to meet the 8X rule for a straight pull to count as a pull point or the sizes and quantity printed on the conduit body may be used when less than 8X. Never seen one listed for what you're pulling so you'll probably need a pull box.
      Rob
      All responses based on the 2017 NEC unless otherwise noted
      Comment
        #4
        That's what I always did, just remember to brace it from end to end before pulling through it.
        Roger
        Comment
          #5
          Roger
          sounds like good advice following a bad experience.
          At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
          Comment
            #6
            Yeah, it was a chore to fix it after it collapsed.
            Roger
            Comment
            Working...
            X
