worxman
- Buford, GA
I am installing a vision system in a C1D1 robotic paint booth. The system consists of a camera and LED ring light that will be housed in a C1D1 XP enclosure. There is a large cable tray that comes in to the booth from the ceiling down to the area where the camera will be installed. My question are:
1. The cable tray just exits through a non-sealed opening in the ceiling of the booth, maybe 15 ft or so above where the painting occurs, is this OK due to the distance from the paint application?
2. Am I ok running conduit from the enclosure out through the opening, using a barrier seal and XP fitting on the exit side?
Trying to avoid cutting through the booth wall and running an extra 80 feet of conduit from the booth to my panel where the camera controller will reside (outside of the booth).
Thanks in advance for the help.
