malachi constant
- Minneapolis
Hi all,
I am the electrical engineer on a project under construction trying to verify whether a couple rooms require classification.
1. Compressed Lubricants Room. Contains the following materials: antifreeze, transmission fluid, diesel exhaust fluid, gear oil SAE 80W-90, lubricating grease, motor oil SAE 15W-40, windshield washer fluid. Vehicles drive into an adjacent bay and pump fluids into the appropriate container.
2. Compressor Room. Contains acetylene and oxygen tanks. These tanks are used to supply welding equipment. They are filled off-site, and once brought into this room are hard-piped into some lines, or are on a cart that allows them to travel around the maintenance bay where welding occurs.
Both spaces have adequate mechanical ventilation to prevent buildup of gases.
The issued drawings call for these rooms to be fully classified at Class 1 Div 2. I think per 500.5 (B)(2)(2) this is likely correct. The contractor has asked us to verify so I thought I would get a second opinion here. Any comments?
Thanks!
Thanks!
