Announcement
Collapse
No announcement yet.
cable in conduit cable end seals
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    what do you all use for end sealing cables, crouse hinds epoxy TSC? it isn't clearly labelled for this. what else is available?
    i'm talking about when you run cable capable of transmitting gases in rigid, don't open the jacket in the seal off but seal the cable end in the enclosure where it terminates.
    #2
    Are we talking about multiconductor cable in conduit?
    [COLOR=black]"Bob"[/COLOR]
    Robert B. Alexander, P.E.
    Answers based on 2017 NEC unless otherwise noted.
    Comment
      #3
      If you were running ONLY multiconductor cable such as TC-ER or MC-HL (no conduit) you could use the TSC Epoxy Sealing compound along with a TMCX connector. But since the cable is routed within conduit, I believe you'll to have to use a conduit seal - such as EYS - open the jacket/separate the conductors and apply Chico compound.
      Comment
        #4
        yes
        Comment
          #5
          i disagree 501.15(D)(2) exception
          cable w/ gas/vapor-tight sheath
          Comment
            #6
            The cable sheath is not the cable core - That’s why you need the EYS/Chico etc
            Comment
              #7
              did u read the exception, you don't have to open the sheath in a seal-off, just seal cable end at termination
              Comment
                #8
                There is no approved UL sealant for multiconductor cable ends when installed in conduit - you need a tmcx for that
                Comment
                  #9
                  doesnt need to be ul approved, just approved (by ahj)
                  Comment
                    #10
                    Wrong.
                    Comment
                      #11
                      Wrong.
                      code reference please
                      Comment
                        #12
                        Wrong.
                        [QUOTE=Dale001289;1919231]
                        ....by an approved means.....
                        article 100
                        Approved- acceptable to the authority having jurisdiction
                        Comment
                          #13
                          article 100
                          “Approved“ and “Approved Means” are not the same thing -
                          Comment
                            #14
                            Wrong.
                            are you thinking of listed? its different
                            Comment
                              #15
                              110.2 Approval. "the conductors and equipment required or permitted by this code shall be acceptable only if approved.
                              informational note. see... definitions of approved....."
                              once again, code reference please. i don't subscribe to dales electrical code just NEC
                              means
                              mēnz/
                              noun
                              [COLOR=#878787 !important][/COLOR]
                              [LIST][*]1.
                              an action or system by which a result is brought about; a method.[/LIST]
                              put the two together and what do you have?
                              Comment
                              Working...
                              X
