Thanks in advance
Are all radio RA switches and multi button devices 3&4 way compatible?
Will the standard 3&4 way still work and override the radioRA switch?
Can levels of dimming and multiple lights be pre programmed into just a radioRA multi button switch?
If one master button is used to turn on multiple light sources at pre programmed levels can you have them in a automatic switching mode to override a standard 3&4 way that could be switched.
Any one have any trouble with the radio RA ?
Is the programing user friendly?
I can't be going out to 're program the client's house can you lock all the devices or program?
