Electriman
- TX
Greetings,
I have been involved to search on lighting design of commercial indoor pools. The requirement for pool lighting is that to try to keep 30 fc at the surface and also avoid glare. The other factor in lighting design is servicing the lighting fixtures if one goes out. Due to the serviceability, putting the lights above the water is rejected unless I find an easy way to service the light.
I was wondering if you have suggestion for lighting.
