Announcement
Collapse
No announcement yet.
Access to can light junction box from below
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    #16
    Originally posted by Greg1707 View Post
    Yes, it has a UL listing. I am just surprised to a see a fixture that is not compliant is available in the "legitimate" electrical market place.
    Wouldn't the "listing" indicate that somehow it is compliant?
    Comment
      #17
      The fixture can be installed, and deemed "accessible", where there is an attic that allows access to the housing junction box from above . . .
      Another Al in Minnesota
      Comment
        #18
        It that fixture was listed the way you mention, then I would hope the manufacturer would indicate it is not suitable to install where not accessible from above. ... Maybe not.
        Comment
          #19
          Looking at the cut sheet, it seems the manufacturer is claiming it is accessible from below. Your picture looks like the BLED2ICN model.
          Based on what I'm reading here though, I would not want to be the one to try to get to the JB after installation.
          http://www.trace-lite.com/resources/...pecs/bled2.pdf
          Comment
            #20
            Do they make laparoscopic electrical tools? I couldn't get two fingers through that hole.
            -Hal
            Comment
              #21
              I'm really trying to behave.
              Master Electrician
              Electrical Contractor
              Richmond, VA
              Comment
                #22
                Don't hold back Larry!
                Comment
                  #23
                  And I really did think about how to phrase that too.
                  -Hal
                  Comment
                    #24
                    Originally posted by Coppersmith View Post
                    All new construction recessed fixtures have a junction box that is inside the ceiling. If there is no attic, that junction box is not accessible without removing drywall. I never thought about it before but that is a code violation. Still, I have installed many and never had an inspector complain.
                    Even inspectors don't see or think of everything. Too much stuff out there. Manufacturers need to do a better job with their stuff. We should all call and e mail manufacturers when we run into such things.
                    Yes, I'll be happy to do a first class job for less than anyone else and take a dollar a week for 10 years.
                    Comment
                      #25
                      BTW, most are accessible by removing the can by the 3 or 4 small screws around the bottom.
                      Comment
                        #26
                        Have tried to remove the actual recessed fixture portion from that housing yet ?
                        From what I see on spec sheet, it looks almost identical to the Juno 2” LED, and the driver with wiring compartment actually slides out of the 2-1/2” hole down below the ceiling ....
                        It looks like this part in the pic is inside that large IC enclosure. I think you can leave he wiring long through the compartment but idk. Open it up and let’s see what’s inside.
                        [COLOR="Blue"]Brought to you by Carl's Jr.[/COLOR]
                        Comment
                        Working...
                        X
