Announcement
Collapse
No announcement yet.
NYC Pre-Action System
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Anyone know if they have to be in RGS conduit by NYC code?
    #2
    Ok, what's a Pre-Action system?
    -Hal
    Comment
      #3
      -Hal
      A type of sprinkler system that has supervisory air in the pipe and only allows water to flow into the pipe when the proper conditions activate, either detection (single interlock) OR detection & air exits the pipe (double interlock).
      NYC only allows single interlock.
      Ron
      Comment
        #4
        Yes, sort of but not exactly. You have a few other choices too. See NYC Electric Code Section 760.131(B) https://www1.nyc.gov/assets/building...rical_code.pdf
        Ron
        Comment
          #5
          Thanks
          Sent from my SM-N960U using Tapatalk
          Comment
            #6
            Commonly called a dry system. There is an air compressor that keeps the piping charged with air.
            -Hal
            Comment
              #7
              -Hal
              Probably not worth arm wrestling about, but NFPA 13 defines them differently. Although pre-action systems normally have dry pipes in the protected area, it is different than a dry pipe system. A Pre-action system requires detection to activate.
              Technically there is such a thing as a non-interlock pre-action system that is essentially a dry pipe system, but nobody really goes through that listing process when a cheapo dry pipe system listing is easier and cheaper to get.
              Ron
              Comment
              Working...
              X
