Announcement
Collapse
No announcement yet.
GFCI Breaker for Pool Lights
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • romex jockey
    replied
    I'm imagining a step potential applies for water, along with those immersed in it
    that said the older industrial ungrounded deltas w/impedance shunts (230.82-4) comes to mind
    one leg to ground was no thing....
    ~S~
    Leave a comment:
  • hbiss
    replied
    Only think I can think of is minimizing the shock hazard. 48V can give you a good tingle.
    -Hal
    Leave a comment:
  • romex jockey
    replied
    Originally posted by hbiss View Post
    Good question because it doesn't only apply to pool LV wiring.
    -Hal
    hmmmm. well i have some thoughts on that, but would like to ask what yours are first Hal
    ~RJ~
    Leave a comment:
  • hbiss
    replied
    -Hal
    Leave a comment:
  • romex jockey
    replied
    I have never seen a GFCI made for LV. Further, because the LV secondary is prohibited from being grounded (IE it's floating), if it should fault to something there would be no risk.
    -Hal
    interesting, was the intent on purpose?....~RJ~
    Leave a comment:
  • brantmacga
    replied
    Originally posted by Dennis Alwon View Post
    The primary side needs gfci protect however I have never seen gfci protection on the secondary side. We also gfci the line and that's all one can do.
    BTw, welcome to the forum
    Does it ? The LV limit referred to in the article is 50v I believe; If you have less than that going to the shell of the pool I don’t believe a GFCI is required.
    Leave a comment:
  • hbiss
    replied
    -Hal
    Leave a comment:
  • Dennis Alwon
    replied
    Leave a comment:
  • JPC PE
    started a topic GFCI Breaker for Pool Lights
    Does the NEC 2017 require a gfci circuit breaker to be used to feed pool lighting circuit if the lighting system in using a NSI Industries TPX300 pool light transformer?
    The TPX300 is a step down transformer 120 primary / 14 v secondary.
    680.23 (A) 3. Says GFCI breakers to be used branch circuits supplying luminaires operating at a voltage greater than the low-voltage contact limit.
    Looking at the situation from the primary side one would say YES to the GFCI
    Looking it from the secondary side one would say NO.
    Advise
    Thanks
Working...
X
