Announcement
Collapse
No announcement yet.
12v Transformer to 12v Rechargeable Battery?
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Can I connect a 12v transformer to a 12v rechargeable battery to recharge the battery?
    #2
    190819-0909 EDT
    CCinPA:
    There is no information on your background.
    Two factors:
    1. What is your definition of a transformer? If a standard AC transformer, then the answer is no.
    2. Batteries are roughly constant voltage DC loads, thus, they must be charged from a current limiting DC source. With proper design that DC source can be supplied from an AC source. That could be a 12 V AC RMS output transformer with appropriate electronics between the transformer and the battery.
    Comment
      #3
      Originally posted by gar View Post
      190819-0909 EDT
      CCinPA:
      Two factors:
      Don't forget it takes about 14 volts to charge a 12 volt battery.
      Cheers and Stay Safe,
      Marky the Sparky
      Comment
        #4
        190819-1168 EDT
        With a 12 V transformer I have 17 V peak available. Thus, with a single diode, and current limiting resistor I can charge a 12 V battery. This needs to be turned off or reduced to a low charge rate after the battery is charged.
        Comment
          #5
          190819-1168 EDT
          If it is low power you could possibly have a variable resistor/rheostat as your current limiting resistor.
          A variac on the input to the 12V transformer is another possible solution.
          Comment
          Working...
          X
