Jon,
can you name one premises or vehicle power system that uses bipolar DC power. I cannot think of one. Only thing I can think of off the top of my head is an internal dc power supply for things like a high power audio amplifier and electronic equipment. The three systems I know of are 24 + VDC, 28 + VDC, 48 –VDC, 130 VDC, and a couple of other odd non referenced higher voltages used in UPS applications. None of these are bipolar, and none share returns on the branch distribution..
Bob,
So how would you size that circuit per NEC of say a 30-amp breaker placed on the hot conductor, say with 50 feet one-way? What rules apply?
All AC and DC systems share common return at some point. For a DC system that point is the DC return bus located inside the Breaker Distribution Frame, it’s AC counter part is the Main Distribution Panel, Breaker or Sub Panel, ect. However once you get to branch distribution each circuit has it own dedicated circuit conductor for each polarity. The only thing in a DC system that is shared is a single wire equipment frame ground.
