I am looking to locate a replacement cable for an alpha pn 2256/3. It is a 20/3 pvc with plastic wrap with a copper drain wire. alpha can't supply it till sometime in late dec. Tried a dozen different suppliers . Any leads will be appreciated. Thanks for any help.
its for a company call msa whos equipment monitor the air in classified locations. LEL, oxygen etc. wiring from board to sensor. suppliers check with belden, ng. need it quickly. thanks
Instead of looking for a 3 conductor PVC, pick up some 4 conductor OAS as it should be readily available since it's a lot more common than a 3 cond. You could use a Plenum cable if it were to speed things up.
