gadfly56
- New Jersey
- Professional Engineer, Fire & Life Safety
I know we've had a recent discussion on egress from these types of rooms. We are working on a project where the room is currently in violation and needs to be brought up to code. The only other apparent location available on one end would require installing a door about 3 feet off the floor, with stairs and a platform. In addition, the space that this door leads to is another electrical room that is connected, circuit-wise, to the first room. The architect is insisting that this arrangement meets the requirements of the NEC, and I can't find anything in the appropriate article (110.26.C) that says directly otherwise. Before anyone asks, the room does not meet either of the two conditions that would obviate the need for two exits. While this may be OK code-wise, neither I nor my colleague feel comfortable with it. Finding an exit is tough enough when your head is going "RUN! RUN! RUN!" without negotiating a flight of stairs, however short, into a space where the fault or whatever may have propagated into. Thoughts?
