Hey there. I can't find where in the code book it tells what the letters on conductor insulation. Like then. Thank you.
Sent from my Moto G (4) using Tapatalk
310.104 gives you some idea but doesn't exactly tell you every detail either.
A few common things:
T: thrermoplastic
H: heat resistant
W: moisture resistant
N: Nylon jacket (mostly for gasoline and oil resistance)
X: cross linked polyethylene
M: machine tool wire
R: rubber
some combination examples:
TW = thermoplastic, moisture resistant
THW = thermoplastic, heat resistant (75C), moisture resistant
THHN = thermoplastic, double heat resistand (90C), moisture resistant
THWN = thermoplastic, heat resistant (75C), moisture resistant, nylon jacket
Then you find a -2 sometimes this turns THWN-2 into same thing as THWN but with a 90C rating. For some reason they'd rather do that than call it THHWN.
