Replacing ground rod due to equipment relocation. Removal of old grounding rods?
thewire
Raleigh
Is there any requirement to point me to about ground rods removal? The equipment will be relocated and will requires new grounding grid. I am trying to tell them to removal the old ones instead abandoned it
roger
Fl
Retired Electrician
Well, there is 250.50, all electrodes present, so it could be argued that if they are still there they must be used.
Roger
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I probably could have pulled that 3' piece of rod by hand. Geez-- you think he would have shown the ability of that tool on an 8' rod :happysad:
infinity
New Jersey
Journeyman Electrician
As Roger pointed out they're technically still present and must be used, that is unless you cut off an inch or two. ;)
Also what exactly is this equipment and is this in a structure? Rods at equipment, despite being a common MFG spec, probably increase risks.
Dennis Alwon
Chapel Hill, NC
I don't agree with the fact that it must be used. If you are driving 2 rods at the new service then that should comply with the code. Adding another rod whether it exists or not is not necessary. Probably a moot point as there probably isn't anyone that would look at it twice.
480sparky
Iowegia
Um.... maybe they used a short rod because
1. it was easier to drive in
2. it made for a shorter video
3. it was just a demo
Fulthrotl
~Autocorrect is My Worst Enema.~
yes, they cut corners and did the demo injustice...just as I implied:)
i'm amazed at why it's a thing.
as for having to use that scrap piece of steel rod stuck in
the ground over there, i have a milwualkee battery powered
4" grinder with a cutoff wheel that will cut it off flush, so
you don't step on it and hurt yourself. i even have a shovel
so i can dig down 6" before cutting it off, so it's even safer.
GeorgeB
ElectroHydraulics engineer (retired)
Greenville SC
Retired
I didn't understand how it worked, but we had 2 utility poled within a few feet of each other behind our house; one was abandoned. My wife hated the look and after about 2 years of calling, a utility truck with some sort of boom came and pulled it, filling the (I'd guess over 6 foot) hole with gravel, then a bag of topsoil on top. VERY professional.
However this worked ... ??? should be able to pull a ground rod.
