IceGuy
- St Paul, MN
I'd like your input on the best way to handle a 1,000' home run length to achieve 3% max voltage drop on a 90 KW array.
1. Use inverter 208V output at array and many, big Al cables (my numbers est $50,000, incl conduit)
2. Use inverter 208V output at array and step up/down using 480v transformers. (my numbers est $38,000, incl conduit)
3. Use inverter 480V output at array and step down to building 208v using 480v transformer. (my numbers est $33,000, incl conduit)
4. Direct bury #6 AWG PV cable for each of 18 strings. Allowable by NEC? Do I need conduit? I don't have any numbers yet.
