THCleveland
New User
- United States
I am part of a university team working on a Department of Energy funded project to develop a Plug and Play residential PV system and am seeking feedback regarding a possible roadmap for such a system to eliminate, or significantly automate, both electrical permitting and inspection. Our scope does not cover structural permitting or inspection.
The prototype system is based around what we call the PV Utility Interface (PUI) which is a smart PV receptacle that is installed by the utility between the existing meter socket and residential meter. The PUI communicates to Plug and Play (PnP) inverters and PV modules. This communication allows several features, including auto-authentication that all inverters and modules are properly listed. The PUI also provides AC arc fault and ground fault protection, continuous verification that only approved modules and inverters are generating, DC connector resistance checks, module Voc checks (indicator of module damage/malfunction), and inverter efficiency checks (indicator of inverter damage/malfunction). We believe the ability to conduct a daily AC insulation resistance test could and should be added to the PUI. It may also be possible to add the ability for the PUI to measure the length and resistance of the AC cable between the last inverter and the PUI as a way to validate that it has adequate current carrying capacity. Without this feature, adequate cable capacity is assured by the unique AC PnP connector that is only available on a single capacity cable, which is equal to the capacity of the PUI with that AC PnP connector. The PUI conducts its system auto-inspection every day before startup for the life of the system. The vision is that the PUI would be listed to a yet-to-be-defined UL standard covering these auto-inspection features. The PUI could also potentially determine which AHJ's jurisdiction it is installed in and engage or disengage features depending on if that AHJ allows PnP PV to waive in-person electrical inspection.
For more details about the system, including some photos of the prototype system, please review this PDF presentation.
Click this link to complete an online survey supplying feedback on the PnP PV system. The survey is expected to take between 10 minutes and 30 minutes depending on the depth of answers. Your feedback here is most helpful to the project.
For discussion in the forum, here are some seed questions:
Thanks for sharing your expertise and experience!
- Considering the plug and play nature of the system connections and the safety provided by the PUI auto-inspection features, do you think such a system could be safely installed by anyone besides a licensed electrical contractor? Where would you draw the line for a "qualified person" for installing the electrical aspects of this system?
- Based on the prototype system description in the attached presentation, do you have any safety concerns were such systems to be installed without a traditional electrical inspection? (assuming all features verified with appropriate UL listings, likely including 1 or more yet-to-be-created Plug and Play related standards)
- As an AHJ, would you consider supporting a policy that would allow this type of Plug and Play system to be installed on homes in your jurisdiction without an electrical inspection? Why or Why not? What information or data would you need to see to consider supporting such a policy?
- Are you concerned about the safety of the AC cable on the exterior of the building between the last inverter on the roof and the PV inlet on the PUI near ground level if there is no visual inspection of the installation? Why or why not?
- Do you think that any portion of the AC cable needs to be in conduit? Why or why not? Note that the PUI in the prototype system includes a 6' cord preinstalled in flexible conduit, this allows the AC cable from the roof to plug into this PUI cord at least 8 feet above grade in most, but not all, situations.
- What is your general reaction to the system and its possibility to eliminate electrical inspections?
