Eros
- United States
I typically use a Soladek when combining strings on a roof with shingles, but is there a combiner designed for a metal roof - seamed or not ? Thx
Different voltages? Combining in parallel strings of different voltages will result in less than optimum performance.I am combining due to multiple strings of different voltages. I have also found that the
AHJ prefers a "string disconnecting" means within site of the array for possible servicing. Not my call
If it's a grounded system, Square D's line of 600V switches are rated for DC and would also be good for disconnecting up to three strings.
For Square D's standard line of 600V switches, that is only true when you connect them with two poles in series. If you have an ungrounded system, you have to do that anyhow. ...
That's an interesting idea that the two poles of an ungrounded system are connected in series and thus meeting such a requirement. Never really thought about it that way before. I was about to say that the switch label doesn't say anything about this, but I had one handy to look at and there's a very fine print asterisk that denotes to use the outer poles. It's not more specific than that. Seems like I could use the two outer poles for two different circuits and still meet the letter of the label.
They have a data bulletin which describes this in more detail:
http://www.bfciaei.org/download/pvapplicationsafetyswitches3110DB0401.pdf
Consider the Siemens Photovoltaic Switches
The Power of Three: Solar Photovoltaic Switches
With its truly innovating design, a single Siemens Safety Switch can perform the work of 3 switches by disconnecting up to 3 separate 600V DC circuits with the help of 3 powerful magnets. One of our switches can replace 3 standard switches resulting in lower material and labor costs. Great results, more savings.
Powerful magnets are incorporated into the line base of the switch and are strategically aligned to dissipate the very hot arc generated when a DC circuit is opened under load. This design innovation allows this new disconnects to perform at a level far beyond that of any conventional safety switch on 600V DC circuits.
Siemens enclosed solar photovoltaic switches are available in 30-200A ratings, in Type 1 and 3R enclosures and in both fusible and non-fusible versions. Both negative ground and positive ground switches are available. They are specifically designed for use in photovoltaic applications, which must comply with article 690 of the NEC.
http://w3.usa.siemens.com/powerdistribution/us/en/product-portfolio/switches/solar/Pages/solar.aspx
