Announcement
Collapse
No announcement yet.
Zig Zag gounding xfmr for 100KW ground mount array
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    The utility is requiring a zig zag grounding xfmr for a 100kw ground mounted array. I have xfmr sizing from them. I know there is a protective relay required to make this setup work. I imagine there are a variety for ways to accomplish this. In hopes of not reinventing the wheel does anyone have a preferred method/ components that work? Thanks, John
    #2
    Interesting. I dont quite follow though. Where is the zig zag to go? Is there already an ungrounded service supplying the site that this will be tied into?
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
    Comment
      #3
      There is another thread about a POCO which is requiring a zig-zag grounding transformer even though the service itself is a grounded wye. There was never a good engineering explanation for that requirement.
      Comment
        #4
        Most of the time, the issue involves the 'distributed generator' becoming 'islanded' from the utility grounded-wye system.
        Generically the term is 'artificial neutral'. A Zig-Zag is simply one style of 'grounding transformer',another common one is often called a 'wye-delta'.
        Impedance grounding, like HRG, is a separate issue from providing a ground reference.
        Just because you can, doesn't mean you should.
        Comment
          #5
          Which was somewhat odd given that the distributed generation in question was a grid tie inverter array which automatically shuts down when islanded.
          Comment
            #6
            Are you saying someone didn't look at all the details before making a judgement?
            Comment
              #7
              I think that I am saying that once the rule was written it was no longer anybody's job to see whether it made sense.
              Comment
                #8
                Comment
                  #9
                  Solution for Effective Grounding
                  Hello Giark, I have a following solution which you might like to use for this application.
                  See if it make sense for you.
                  Click image for larger version
ID:	2372554Click image for larger version
                  Comment
                  Working...
                  X
